Make New Formula Column return references to the newly created columns
JMP17 has new function called New Formula Column. It would be nice if it were to return the references to the newly created columns in a list, in similar manner as << New Column does for single column. This would make using this function easier
Names Default To Here(1);
dt = Open("$SAMPLE_DATA/Big Class.jmp");
new_col = dt << New Column("Log2[height]", Numeric, Continuous, Formula(
	Log(:height, 2)
new_cols = dt << New Formula Column(Operation("Log 2"), Columns(:height, :weight));
Show(new_col, new_cols);
8 Comments
Hi @jthi, thank you for your suggestion! We have captured your request and will take it under consideration.
Mauro_Gerber
Level V
@Sarah-Sylvestre Can you please also add this function to
ref = dt << Text to Columns(columns( :Y),Delimiters( "_" ));
since its sometimes hard to know how many new column are created when executing the function.
hogi
Level XIII
JMP18: available now.
Mauro_Gerber
Level V
Good news, although it would be nice to extend this feature to "Text to Columns" too. @Sarah-Sylvestre
jthi
And would be nice if JMP could decide what they want to return to make it somewhat consistent
	Log(:height, 2)
new_col = Column("Log2[height]");
new_cols = {:"Log2[height] 2"n, :"Log2[weight]"n};
hogi
Level XIII
thank you for the hint : )
	Log(:height, 2)
Eval (new_col)
EvalList(new_cols)
hogi
Level XIII
Regarding  Text to columns there is also another wish to add an option to generate formulas:
Text to Columns
Status changed to: Delivered
Hello all! Thank you for the feedback. I am marking this as delivered but your comments have been passed along to the developer.
