New to JMP? Let the Data Analysis Director guide you through selecting an analysis task, an analysis goal, and a data type. Available now in the JMP Marketplace!
Hey @mia_stephens, I get the error when I try and use access variable importance(AVI). It will happen for all three types of AVI. I just tried it and nothing gets reported to the log when it happens. What I have to do to work around it is go into column viewer, sort by "N missing" then look to see what columns are missing the most data, and then start removing the columns with the most missing data until I can get the "AVI" to run. Sometimes its obvious but many times its not.
@shampton82 - We have reviewed your request and think it will be a great addition to JMP. This request is in the queue of items to work on in a future release.
