Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
JMP will suspend normal business operations for our Rest and Recharge Day on Friday, October 2, 2026.
Hey @mia_stephens, I get the error when I try and use access variable importance(AVI). It will happen for all three types of AVI. I just tried it and nothing gets reported to the log when it happens. What I have to do to work around it is go into column viewer, sort by "N missing" then look to see what columns are missing the most data, and then start removing the columns with the most missing data until I can get the "AVI" to run. Sometimes its obvious but many times its not.
@shampton82 - We have reviewed your request and think it will be a great addition to JMP. This request is in the queue of items to work on in a future release.
