JSL function to get the current status of modifier keys
☑ cool new feature
☐ could help many users!
☐ removes something that feels like a „bug“
☐ nice to have
☐ nobody needs it
In JSL there are functions like
is control key()
to get the current status of modifier keys,
unfortunately,
This function does not return the current state of the control key but rather the state of the control key at the start of another event like mouse click or key press.
Checking for modifier keys (ctrl, alt, shift) in script without mouse trapping
As  JMP does have an internal function to get the modified key state at any time but this is not exposed via JSL.
... could you please provide a JSL function to expose the current status of a modifier key
Why is this idea important?
This will allow JSL programmers to generate Toolbars and commands in the menu on a completely new level:
depending on the status of a modifier key, different actions could be triggered (!!!)
similar add-on functionality could also boost standard platforms:
- A user could specify a DEFAULT action in the preferences. If a user clicks on Subset, Summary, Tabulate, Graph Builder - holding SHIFT - the DEFAULT action is executed ... without any need to manually enter the settings.
- with a control key, the action could be triggered with the RECALL settings.
3 Comments
hogi
Level XI
application case: send to PPT
- default: send a screenshot to powerpoint
- with CTRL pressed, send a vector graphics to powerpoint
hogi
Level XI
application case: subset
- default: create a linked subset
- with CTRL : create a subset which is not linked
- with Shift : just include columns which are selected at the moment.
