Grey Triangle: Edit -> Copy Picture
Hello,
I would like to request that the Copy Picture command under Edit in the grey-triangle menu be moved up one level for easier access. Copy Picture isn't really an edit command so it seems to be misplaced there, in addition to requiring additional navigation.
Thanks and regards
Mehul Shroff
cc: @PatrickGiuliano
4 Comments
Hello @MShroff, Thank you for your engagement on the Wishlist!
Just to clarify with some pictures:
Your request would be to move the 'Copy Picture' item from the Submenu option under Edit to the Primary Menu option, correct?
Please let me know if I have captured this incorrectly.
Cheers, @PatrickGiuliano
MShroff
Level V
Hello @PatrickGiuliano - yes, that is correct.
Regards
Mehul Shroff
Hi @MShroff, thank you for your suggestion! We have captured your request and will take it under consideration.
Status changed to: Not Planned For Now
Although we do not plan to deliver this request now, we are holding onto it for a future release and will update this issue if it becomes a priority. Thank you for the idea!
