Grey Triangle: Edit -> Copy Picture
Hello,
I would like to request that the Copy Picture command under Edit in the grey-triangle menu be moved up one level for easier access. Copy Picture isn't really an edit command so it seems to be misplaced there, in addition to requiring additional navigation.
Thanks and regards
Mehul Shroff
cc: @PatrickGiuliano
8 Comments
Hello @MShroff, Thank you for your engagement on the Wishlist!
Just to clarify with some pictures:
Your request would be to move the 'Copy Picture' item from the Submenu option under Edit to the Primary Menu option, correct?
Please let me know if I have captured this incorrectly.
Cheers, @PatrickGiuliano
MShroff
Level VI
Hello @PatrickGiuliano - yes, that is correct.
Regards
Mehul Shroff
Hi @MShroff, thank you for your suggestion! We have captured your request and will take it under consideration.
Status changed to: Not Planned For Now
Although we do not plan to deliver this request now, we are holding onto it for a future release and will update this issue if it becomes a priority. Thank you for the idea!
mia_stephens
Status changed to: Delivered
In JMP 18 the context menu on graphs has been reorganized. Copy Graph has been promoted to the top-level of the context menu to make it more accessible.
MShroff
Level VI
Thanks but this only works for the graph. If I want to copy the whole block, I still have to go through the grey triangle -> Edit -> Copy Picture.
mia_stephens
I might be missing something, but it seems that the selection tool (the fat plus sign in your toolbar) can be used to select the parts of the output you are interested in copying.
MShroff
Level VI
With the selection tool, one has to specifically format the copied selection as a picture when pasting in PowerPoint. The Edit -> Copy Picture command does not have this issue and one can directly paste the copied picture without additional formatting. IOW, the selection tool is not very convenient to use.
Thank you.
