  • Use World Cup data to build models, explore spatial relationships, and create informative visualizations in JMP. Register. July 17, 2 pm US Eastern Time.
Graph Builder: Line - possibility to add breaks (💚)
☑ cool new feature
☑ could help many users!
☑ removes a „bug“
☐ nice to have
☐ nobody needs it
#myTop10_2024
For Line Graphs in Graph Builder, there is a cool feature row order.
If it's selected, the line doesn't connect data points from left to right in the graph - but along the order in which they appear in the data table.
Instead of this graph:
the user gets this graph:
Much better ...
But unfortunately, there are those nasty jumps "back" to the next curve.
Of course, for simple graphs, you can use a column (here "Station") as an overlay to produce 3 separate curves, without the zigzag.
But already with slightly more complicated graphs like this one here: Graph Builder. Combine Smoother and Line - how? the user reaches the limits of current Graph Builder (v17, v18).
  1.  With sorted data in the data table, a step from right to left indicates a new curve.
    So, with row order enabled, there could be an additional option to draw lines  "only left -> right".
    If this option is enabled, line for steps from higher to lower values will disappear -> the jump back-lines are gone : )
  2. Fallback:  Rows with missing y value could be used to add a break in line graphs (even somewhere in the center of the graph - cool, right?)
    ... if there was an option: *)
Why is this idea important?
a tiny change of the program - a  tremendous improvement for the users:
dt =Open( "$SAMPLE_DATA/Functional Data/Weekly Weather Data.jmp" );
dt << New Column( "group",Character,"Nominal",Formula( Substr( :STATION, 8, 1 ) ));
Graph Builder(
	Size( 523, 407 ),
	Summary Statistic( "Median" ),
	Graph Spacing( 4 ),
	Variables( X( :DATE ), Y( :TAVG ), Overlay( :group ), Color( :group ) ),
	Elements( Line( X, Y, Legend( 31 ), Row order( 1 ) ) ),
	Local Data Filter(
		Add Filter(
			columns( :STATION ),
			Where( :STATION == {"USW00003195", "USW00003868", "USW00003949"} ),
			Display( :STATION, N Items( 15 ) )
19 Comments
hogi
Level XIII
wow, very elegant workaround :)
Transfer the solution from Overlay to Color. Here we don't have the restriction of "one column only".
-> I will definitely use it in the future!
Unfortunately, won't work for many of my cases -- when the formatting options of Color Dropzone is needed to differentiate between entries along additional dimensions.
@XanGregg : Any chance that Graph Builder will be able to skip the backwards line segments ( via an option in the GUI)?
hogi
Level XIII
Maybe even a setting in the preferences ?
see  "Overlay limit" / from Graph Builder Problem with Lines
XanGregg
Regarding skipping backwards line segment connections, there is a new JMP 19 Ordering option in the Line element called "Row Ascending" which addresses the issue for cases like this.
hogi
Level XIII
@XanGregg wow, amazing! Thanks!
like a Christmas present.
Where can I find it  - can you share an example ?
XanGregg
Oops! I lost track of the timing. It's really something you can try in the next EA. So not quite Christmas, early 2026. I'll see if I can edit my reply.
hogi
Level XIII
Ah, wonderful - definitely feels like a Christmas Present:
... some extra days of joyful anticipation ; )
hogi
Level XIII
A tiny switch – and at the same time an enabler for a wide field of plots.
Hello! This feature will be available in JMP 20. In Graph Builder, row order breaks have been added for grouped spaghetti lines. If you’re an authorized JMP user, you can try it now in JMP 20 EA 1. You can request access to the program by visiting JMP.com/earlyadopter.
hogi
Level XIII
Works great -  many, many thanks!
With the new option row ascending,
Graph Builder(
	Variables( X( :DATE ), Y( :TAVG ), Overlay( :group ) ),
	Elements( Line( X, Y, Ordering( "Row Ascending" ) ) )
 JMP can now produce this graph :
instead of this one:
