Fix JMP Update
Current JMP update does not handle data changes, only data additions.
Rather than just appending data, fix the UPDATE so that it does a full refresh of the data including deletions, changes and additions.
Why is this idea important?
Often SCRIPTS for analysis (e.g. Graphs in a JMP Project) are often saved to the data table.  When you want to do the same analysis on a "refreshed" dataset you must use the same table or recreate all of that work.  There is a work around that a JMP Tech. Service individual provided.  The request is to make this functionality part of JMP rather than having to create another script.  Here are notes on the work around:
3 Comments
hogi
Level XIII
@GraphOTE thanks for your suggestion.
@GraphOTE , than you for the request. We will investigate this internally.
