Enable string concatenation in "New Formula Column" -> "Combine" for numerical columns
I have two columns of integers (along with a bunch of other columns), and would like to overlay in Graph Builder on the pairing of the two --
Since overlay only accepts a single variable, I typically do this by creating a new column with both columns comma-separated by using the "New Formula Column" -> "Character" -> "Concatenate with comma", but when both columns are numeric, concatenating with comma is no longer an option, requiring a custom formula with char() and "||".
Request adding a "Concatenate with comma" option to "New Formula Column" -> "Combine" menu.
9 Comments
jthi
Other wish list item related to this make NewFormulaColumn/Character more flexible
hogi
Level XIII
good to see that other people have similar "doors locked" ...
I generated my own Add-In Toolbar item to solve the issue.
another workaround: add an empty "character" column and cocatenate the tree of them.
(As soon as there is one character column included, concatenate is available.)
Hi @BHarris, thank you for your suggestion! We have captured your request and will take it under consideration.
Status changed to: Duplicate
Hello @BHarris! I am going to mark this request as a duplicate. The request linked in the comments is also asking for the ability to concatenate numeric columns with a comma.  The duplicate request is currently being investigated for potential inclusion in a future release.  Let me know if you have any questions!
BHarris
Level VII
That other request is to allow columns to be concatenated with another character.  The request to enable numeric columns to be concatenated is a secondary request there.  But as long as the second-part of it doesn't get ignored/lost, that's fine with me.
hogi
Level XIII
How about splitting the two topics?
- this wish here to enable string concatenation even if all variables are numbers
--> prio
- https://community.jmp.com/t5/JMP-Wish-List/make-NewFormulaColumn-Character-more-flexible/m-p/543650#... - restricted to: add more flexibility
--> lower prio (as you already added many individual versions of concatenate with ... in the mean time;
so, kind of too late - if you don't want to remove the other versions and if the list should not get too long)
Thanks for all the discussion everyone! I have captured all aspects of this wish in our system, but I will reopen this wish so that people can vote on the topics separately if they wish. So, the items will be split as @hogi stated below. I hope that works for everyone!
hogi
Level XIII
Hi @Sarah-Sylvestre ,
seems that splitting the wishes was not a good idea.
the "low-prio half" of the topic (concatenate with comma, underscore ...) is already delivered for a while:
but the top-prio part (same functionality for numeric columns) is still pending :(
