Process Map / Value Stream Map
A process map or value stream map builder feature would be awesome.  The user would enter the process step name and have the option to enter additional elements like factors, responses, noise, specifications, levels, cycle times, etc. for each step.  The user could also select factors and create a DOE or link process steps to capability and control chart data sets to identify bottlenecks, critical chains, or areas for improvement.  JMP could also develop analysis platforms focused on the relationships between process steps.
5 Comments
Hi @Josh1, thank you for your suggestion! We have captured your request and will take it under consideration.
mia_stephens
LocalMeerkat106
Level I
All of my team's VSM data is already in JMP tables. This would be an incredible feature to have available.
ehchandlerjr
Level V
Just learned about process maps, and found this wishlist item. Our lab does a lot of process development, and this would be an amazing addition.
