I typically have data for multiple product codes and plants in one file (pls see attached example). I would like to do Capability Analysis for each product code and plant in this file. Each product code has a different specification. I would like to pull the specification in from a "Spec Limit" file (pls see attached example).
Please note that there are too many product codes in a file for sub-setting each one. It would result in too many files to handle.
If it is easier to have a scripting answer short term, I am fine with that. Long term I would like to see it integrated into JMP under the "Manage Spec Limits" option.
Example for Multiple PC Spec Request.jmp
Example for Spec Limit file.jmp
