Add Interaction Profiler to Mixed Model Report
Hi,
I'm working on a data set looking that works best when I use the mixed model personality in the Fit Model platform. I'm used to the ability to show the interaction profiler in the standard least squares personality; as far as I can tell that is not available in the mixed model personality. This is despite the fact that the SLS with REML is functionally the same as the mixed model according to your webinar on the subject. I realize that in the factor profiling window in the mixed model report you can click on the different categorical effects in the profiler which updates the slopes of the fixed effects and so on, but it is really helpful to see those lines on the same plot as you can with the interaction profiler in the SLS personality. Seems like it would be a fairly easy thing to implement as well. Maybe I missed something and it is already there but as of yet I cannot find it.
Cheers,
Stephen
