Can you please add in some additional options for sorting the items showing in the data filter? Items such as:
-Select only the top 10 by count or even better yet Top "X" where X is a user input
-Sort by another column and function: so if you had a part type column and the number of defects by each lot number of the part then being able to sort the parts in the filter by the average defects by part or by the sum of defects per part.
