JMP will suspend normal business operations for our Winter Holiday beginning on Wednesday, Dec. 24, 2025, at 5:00 p.m. ET (2:00 p.m. ET for JMP Accounts Receivable).
We’re retiring the File Exchange at the end of this year. The JMP Marketplace is now your destination for add-ins and extensions.
Document and support the DisableJMPPro() function. For those individuals that support a community of JMP users, some that do not have JMPPro, being able to develop and/or test standard JMP programs is important.
Hi @txnelson, thank you for this suggestion. Unfortunately, DisableJMPPro() does not completely disable everything, so this is not a function we feel comfortable documenting, publicizing or formally supporting. A more reliable solution is to either run the two products side by side or to swap out the license files.
Changing the status of this request, but we're happy to reopen and explore other potential solutions.
