Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
JMP will suspend normal business operations for our Rest and Recharge Day on Friday, October 2, 2026.
For Deming regression, perhaps Fit Orthogonal would be useful for you? It's available under the Red Triangle in Fit Y by X. There are different options depending on how you want to account for differences in the variances of X and Y.
Thanks a lot for towards the menu. The graph axis options mentioned would be helpful for fast judgement and as guide to easily see offset and/or change in gradient. As demonstrated in folllowing blog:
The author (Russ Wolfinger) just commented in that thread that it could be time for JMP to add the functionality as a specific platform, not as an Add-In, so it is justifiable.
I would not only go for Deming regression but a Method comparison platform including Passing-Bablok, so that it can be used under regulatory guidelines.
But good to hear that this just refers to wish 2&3.
As @jules has already pointed out Deming regression (with specified variance ratio ...) is already available from the "Fit orthogonal" submenu. Kind of funny, as the title of the submenu "fit orthogonal" sounds similar to the special case "equal variance" - which is also listed :)
To be honest, I wouldn't have expected to find the Deming regression there. So, thanks @jules for the hint :)
Concerning:
for "Fit Y by X“ platform an option (check box) for a reference line y=x
We also added Passing-Pablock regression in version 17. As part of our new approach to managing wish lists, several older items were archived to simplify the list and allow us to focus on the most recent and relevant requests. In this case, the request had mostly been fulfilled but never updated on the Community.
