取消
显示结果
显示  仅  | 搜索替代
您的意思是:
选择语言 隐藏翻译栏
Col Median (and others): add "Where" option
☐ cool new feature
☑ could help many users!
☐ removes a „bug“
☐ nice to have
☐ nobody needs it
#myTop10_2022
There is a set of posts with questions how to restrict the Col ... aggregation functions to a specific subset.
Compute Column Mean while restricting observations used
JMP10: Col Max() and Col Min() functions returned the data from excluded row
Col Functions and Row States
How do I use the Col Maximum Formula with a "where" condition
Exclude data in formula
Application cases:
  • excluded rows from the aggregation:
    Col Max(if(not(excluded()), :weight,.),: sex)
    or even shorter (if one doesn't need values in the excluded rows);
    Col Max(:weight, :sex, :excluded())
  • Benchmark some data with a reference data set (country A in this post)
    :data / Col Maximum(if(:country="A", :data,.))
  • calculate relative performance over time (divide all values at time t>=t0  by values at t=t0)
    (here the Col Mean is actually to get the value for :time=0 to the other rows.:)
    : data / Col Mean(if(:time=0, :data, 0) :batch, :sampleID)
As one can see in the examples above, the easy solution is an If statement inside the Col xyz aggreagtion:
col Mean( if(:sex=="M", :weight,.), :age);
col Mean( if(not(excluded()), :weight,.), :age)
The problem:
The approach is EXTREMELY slow - if the subset if-condition contains a  string comparison:
How-do-I-use-the-Col-Maximum-Formula-with-a-where/M78599
Then the time scales quadratically with the number of rows and even for small data sets with just a few 1000 entries the calculation takes seconds.
For data sets with some million entries it would take months (!!!) - but will be stopped by a timeout and an error message pops up. Not nice!
My wish:
fix the bug
Even better:
Provide an additonal where option for Col xyz aggreagtions
  • which fixes the timing problem automatically: first restricts the data set, then applys the aggregation (--> much faster, even if the cool "col..." speedup has a  bug)
  • which  make subset definitions easier,
    instead of (*), you just need:
col Mean(:weight, :age, where(:sex=="M"))
col Mean(:weight, :age, where(not(excluded())))
timing examples, copied from here
corrected version - in a prev. version the screenshot showed [ms] instead of [s]
8 条评论
状态已更改为: Acknowledged
Hi @hogi, thank you for your suggestion! We have captured your request and will take it under consideration.
SamGardner
Level VII
状态已更改为: Investigating
SamGardner
Level VII
状态已更改为: Under Consideration
@hogi this is being looked at closely as we work on ways to improve how Where( ) clauses are used throughout JMP.  Thanks for the suggestion!
hogi
Level XIII
hogi
Level XIII
for the time till where(...) will be available in a future version of Jmp, one can speed up the the col aggregation by orders of magnitude via the workaround
changing the data type to numeric - or use a numeric formula column.
https://community.jmp.com/t5/Discussions/Tips-and-Tricks-best-practice-with-JMP-JSL/td-p/662686
hogi
Level XIII
Thanks, @SamGardner  , @Sarah-Sylvestre , it's available now in JMP18 : )
Before changing the status to Delivered, could you please check if the usage of Where is like in tended in this Snippet?
Compared to the original approach is extremely slow : (
dt = Open( "$SAMPLE_DATA/Airline Delays.jmp" );
Print("old aproach");
t0 = hptime();
New Column( "max - 1st of month",
	Formula( Col Maximum( if(:Day of Month == 1 , :Arrival Delay,.), :Month) )
dt << run formulas();
show((hp time()-t0)/1000000); // 0.5s
Print("new  aproach - with Where");
t0 = hptime();
	Formula( Col Maximum( :Arrival Delay, :Month, Where( :Day of Month == 1 ) ) )
show((hp time()-t0)/1000000); // 140s
hogi
Level XIII
Print("new  aproach - with Where, semi-bugfix");
t0 = hptime();
 myWhere = Where( :Day of Month == 1 ) ;
Eval (Eval Expr(New Column( "max - 1st of month",
	Formula( Col Maximum( :Arrival Delay, :Month, Expr(myWhere) )
show((hp time()-t0)/1000000); // 40s - better but still way too slow ...
hogi
Level XIII
Ah, doesn't work yet  : (
Names Default to Here(1);
	Formula( Col Minimum( :weight, :sex, Where( :age ==17 ) ) )
