  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Calling native platforms with required user input from scripting
I think it would be absolutely awesome, if I could do something like this.
Names default to here(1);
dt = open("$SAMPLE_DATA\Big Class.jmp");
biv = dt << Bivariate();
Now biv is a "Scriptable[]", and that's okay.  But when I push okay, I'd love it if biv became the expression that you would get if you saved script to script window.
That way I can do something like
while(type(biv)!= "Expression",
	if(biv == "User Canceled", stop());
	wait(.3);
biv = Eval(biv);
And it would wait as long as necessary for the user to input what  they needed to.
I put in a statement that would check if the user canceled assuming that the user canceling would have some effect as well.
The obvious problem with this is that I would be doing the analysis twice.
This is related to this community item , I just really don't like rewriting the UI for platforms.
2 Comments
gzmorgan0
Super User (Alumni)
@vince_faller ,
I agree that enabling the JMP platform interface would be cool.  Even though I like the non-Modal  platform interface, what you are describing is something like
biv = dt << Bivariate( <<Modal, <<Return Result );
// or alternately
biv = dt << Bivariate Dialog();  //just the script expression is returned
That said, JMP  enabling winlist = Get Window List () with a type option and Save ByGroup Script to Data Table( "name", <<Prompt(0|1), <<Replace(0|1) ) will allow yo to do what you want, but with a bit of work. Just add what you want to do (your script, as an expression or include file)  to the doSomething expression: just as you would do for any non-modal dialog.
biv = dt << Bivariate( );
opt = 0;
onCancel = Expr( opt = -1 );
onOK     = Expr( opt = 1 );
doSomething = Expr(
  winlist = (Get Window List(Type("Reports")) << Get Window Title());
  If (nitems(winlist) >0,
       win = Window(winlist[nitems(winlist)]);
   // should have an error check for Bivariate, this assumes the last report is the report you want
       biv = win[OutlineBox(1)] << get scriptable object;
       biv << Save By Group Script to Data Table("user",<<Prompt(0), <<Replace(1)) ;
       snames = dt << Get Table Script Names;
       s = dt << Get Script( snames[nitems(snames)] );
       // or use s= dt << Get Table Script("user") since you specified a name
       show(s);
dlgs = Get Window List(Type("Dialogs"));
biv_dlg = dlgs[nitems(dlgs)];
biv_dlg[Button Box(7)] << set script (onCancel);
biv_dlg[Button Box(6)] << set script (onOK);
biv_dlg << On Close(
   show(opt);
   if(opt < 1,
      Beep(); Caption("User Cancelled"); wait(1); Caption(remove); Stop(),
  //else
      doSomething
Ryan_Gilmore
Community Manager
Status changed to: Archived
