Calling native platforms with required user input from scripting
I think it would be absolutely awesome, if I could do something like this.
Names default to here(1);
dt = open("$SAMPLE_DATA\Big Class.jmp");
biv = dt << Bivariate();
Now biv is a "Scriptable[]", and that's okay.  But when I push okay, I'd love it if biv became the expression that you would get if you saved script to script window.
That way I can do something like
while(type(biv)!= "Expression",
	if(biv == "User Canceled", stop());
	wait(.3);
biv = Eval(biv);
And it would wait as long as necessary for the user to input what  they needed to.
I put in a statement that would check if the user canceled assuming that the user canceling would have some effect as well.
The obvious problem with this is that I would be doing the analysis twice.
This is related to this community item , I just really don't like rewriting the UI for platforms.
2 Comments
gzmorgan0
Super User (Alumni)
@vince_faller ,
I agree that enabling the JMP platform interface would be cool.  Even though I like the non-Modal  platform interface, what you are describing is something like
biv = dt << Bivariate( <<Modal, <<Return Result );
// or alternately
biv = dt << Bivariate Dialog();  //just the script expression is returned
That said, JMP  enabling winlist = Get Window List () with a type option and Save ByGroup Script to Data Table( "name", <<Prompt(0|1), <<Replace(0|1) ) will allow yo to do what you want, but with a bit of work. Just add what you want to do (your script, as an expression or include file)  to the doSomething expression: just as you would do for any non-modal dialog.
biv = dt << Bivariate( );
opt = 0;
onCancel = Expr( opt = -1 );
onOK     = Expr( opt = 1 );
doSomething = Expr(
  winlist = (Get Window List(Type("Reports")) << Get Window Title());
  If (nitems(winlist) >0,
       win = Window(winlist[nitems(winlist)]);
   // should have an error check for Bivariate, this assumes the last report is the report you want
       biv = win[OutlineBox(1)] << get scriptable object;
       biv << Save By Group Script to Data Table("user",<<Prompt(0), <<Replace(1)) ;
       snames = dt << Get Table Script Names;
       s = dt << Get Script( snames[nitems(snames)] );
       // or use s= dt << Get Table Script("user") since you specified a name
       show(s);
dlgs = Get Window List(Type("Dialogs"));
biv_dlg = dlgs[nitems(dlgs)];
biv_dlg[Button Box(7)] << set script (onCancel);
biv_dlg[Button Box(6)] << set script (onOK);
biv_dlg << On Close(
   show(opt);
   if(opt < 1,
      Beep(); Caption("User Cancelled"); wait(1); Caption(remove); Stop(),
  //else
      doSomething
Ryan_Gilmore
Community Manager
Status changed to: Archived
