  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Bar Labels for 0 value
It is important to distinguish between a zero value and a missing value. However, if you label a bar chart in Graph Builder with values and the value is zero, then the label does not display. The reader of the chart no longer knows if it was a recorded zero or a missing value.
There seems to be no way to force the 0 label onto the chart. Trying to make the value non-zero (i.e. 0.00001) just makes the label show the value - you cannot change the numeric detail of the label (which is a problem already noted: https://community.jmp.com/t5/Discussions/How-to-change-number-of-decimal-places-in-Bar-chart-labels-...)
A solution already shown for zero values (
https://community.jmp.com/t5/Discussions/Show-zero-percent-in-bar-chart/m-p/208592) seems to only work for percentages, which my dataset does not have.
1 Comment
hogi
Level XIII
solution in a future version of JMP:
:folded_hands: Column Property: Inclusive Values
