Add the power of 10 scientific format to the standard number formats in JMP
I would like to suggest that you add the power of 10 scientific format to the standard number formats in JMP - for tables, graphs.
The format in question looks like this: 1 × 10⁴
8 Comments
Sarah-Sylvestre
Level V
@yevgen - Thank you for your suggestion! We have captured your request and will take it under consideration.
SamGardner
Level VII
Status changed to: Needs Info
@yevgen thank you for the idea.  Can I ask what is your reason for wanting this format?  Can you provide more details?
yevgen
Level II
It is the most common scientific number format we use in natural sciences. You can look at all the peer-reviewed papers and see it used everywhere. Thank you so much for considering implementing it.
Sarah-Sylvestre
Level V
Thank you for the information! We are evaluating this for future release.
Sarah-Sylvestre
Level V
Hello @yevgen. We are still evaluating this request for inclusion in a future release.  In the meantime, one of our developers has provided a workaround. You can do custom formats in JMP with JSL.  Here is an example with GB axis:
Open( "$SAMPLE_DATA/CrimeData.jmp" );
Graph Builder(
	Variables( X( :Year ), Y( :Population ) ),
	Elements( Points( X, Y, Legend( 6 ) ), Smoother( X, Y, Legend( 7 ) ) ),
	SendToReport( Dispatch( {}, "Population", ScaleBox,
		{Format( "Custom",
			Formula(
				Local( {supers = "⁰¹²³⁴⁵⁶⁷⁸⁹", d, parts},
					parts = Words( Format( value, "Scientific", width, dec ), "e" );
					Substitute Into( parts[2], "+", "", "-", "⁻" );
					For( d = 0, d <= 9, d++,
						Substitute Into( parts[2], Char( d ), Substr( supers, d + 1, 1 ))
					parts[1] || " × 10" || parts[2];
		), Min( 0 ), Max( 39248000 ), Inc( 5000000 ), Minor Ticks( 0 )}
See more Reply All: Scientific notation such as 6.02×10²³ using custom axis formats
This is not the ideal solution, but I wanted to let you know in case you want to give it a try.  I will update you once we have prioritized your request.
Sarah-Sylvestre
Level V
Hi @yevgen , we plan to make this available in JMP 18! You will be able to find it in Scientific and Engineering column formats and in the Axis settings.
Great news!
Echo @yevgen
FYI @InaWanner.
Sarah-Sylvestre
Level V
Status changed to: Delivered
