Add option to not contain all windows to JMP Project's
Participating in JMP Lab during JMP Discovery Summit Europe 2023 where I did use Projects (I don't really use them, but I do see that there could be potential) with multiple data tables and reports at the same time.
One of the biggest reasons why I don't use JMP projects at all, is that it will contain all (non-modal) windows to the project. What I would like to see is to somehow limit which will be added to project (check box selector for different window types for example, JMP17 provides quite a few of different window types for example). Below is an example where Fit Y by X platform is contained in the Project
but I would like it to open as the normal Launcher window like it would open from data table and then add the report to project when I click Run.
Why is this idea important?
Improves the user experience of using JMP Project's by not containing everything inside the project.
2 Comments
hogi
Level XIII
I agree so much.
Projects could be great - but putting every data table and plot into the same window steals Jmp large part of its power to be useful.
jc510_2
Level III
Definitely agree with adding more flexibility for non-modal windows!
