%3CLINGO-SUB%20id%3D%22lingo-sub-612257%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EAjouter%20une%20option%20pour%20ne%20pas%20contenir%20toutes%20les%20fen%C3%AAtres%20du%20projet%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-612257%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3EQu'est-ce%20qui%20a%20inspir%C3%A9%20cette%20demande%20de%20liste%20de%20souhaits%26nbsp%3B%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EParticiper%20au%20JMP%20Lab%20pendant%3CSPAN%3E%20JMP%20Discovery%20Summit%20Europe%202023%20o%C3%B9%20j'ai%20utilis%C3%A9%20des%20projets%20(je%20ne%20les%20utilise%20pas%20vraiment%2C%20mais%20je%20vois%20qu'il%20pourrait%20y%20avoir%20du%20potentiel)%20avec%20plusieurs%20tableaux%20de%20donn%C3%A9es%20et%20rapports%20en%20m%C3%AAme%20temps.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EQuelle%20est%20l%E2%80%99am%C3%A9lioration%20que%20vous%20souhaiteriez%20voir%20%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EL'une%20des%20principales%20raisons%20pour%20lesquelles%20je%20n'utilise%20pas%20du%20tout%20les%20projets%20JMP%20est%20qu'ils%20contiendront%20toutes%20les%20fen%C3%AAtres%20(non%20modales)%20du%20projet.%20Ce%20que%20j'aimerais%20voir%2C%20c'est%20limiter%20d'une%20mani%C3%A8re%20ou%20d'une%20autre%20ce%20qui%20sera%20ajout%C3%A9%20au%20projet%20(s%C3%A9lecteur%20de%20case%20%C3%A0%20cocher%20pour%20diff%C3%A9rents%20types%20de%20fen%C3%AAtres%20par%20exemple%2C%20JMP17%20fournit%20un%20certain%20nombre%20de%20types%20de%20fen%C3%AAtres%20diff%C3%A9rents%20par%20exemple).%20Vous%20trouverez%20ci-dessous%20un%20exemple%20o%C3%B9%20la%20plateforme%20Fit%20Y%20by%20X%20est%20contenue%20dans%20le%20projet.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22jthi_0-1678870953356.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jthi_0-1678870953356.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jthi_0-1678870953356.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F51038iB2388069880BB625%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22jthi_0-1678870953356.png%22%20alt%3D%22jthi_0-1678870953356.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Emais%20j'aimerais%20qu'il%20s'ouvre%20comme%20la%20fen%C3%AAtre%20de%20lancement%20normale%2C%20comme%20s'il%20s'ouvrait%20%C3%A0%20partir%20de%20la%20table%20de%20donn%C3%A9es%2C%20puis%20ajoutait%20le%20rapport%20au%20projet%20lorsque%20je%20clique%20sur%20Ex%C3%A9cuter.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EPourquoi%20cette%20id%C3%A9e%20est-elle%20importante%20%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EAm%C3%A9liore%20l'exp%C3%A9rience%20utilisateur%20lors%20de%20l'utilisation%20des%20projets%20JMP%20en%20ne%20contenant%20pas%20tout%20ce%20qui%20se%20trouve%20%C3%A0%20l'int%C3%A9rieur%20du%20projet.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-612257%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EOrganisation%20du%20contenu%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-612534%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%20%3A%20Ajouter%20une%20option%20pour%20ne%20pas%20contenir%20toutes%20les%20fen%C3%AAtres%20du%20projet%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-612534%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CBLOCKQUOTE%3E%3CHR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F14366%22%20target%3D%22_blank%22%3E%40jthi%3C%2FA%3E%20a%20%C3%A9crit%3A%3CP%3EL'une%20des%20principales%20raisons%20pour%20lesquelles%20je%20n'utilise%20pas%20du%20tout%20les%20projets%20JMP%20est%20qu'ils%20contiendront%20toutes%20les%20fen%C3%AAtres%20(non%20modales)%20du%20projet.%3C%2FP%3E%3CHR%20%2F%3E%3C%2FBLOCKQUOTE%3E%3CP%3EJe%20suis%20tellement%20d'accord.%3CBR%20%2F%3E%20Les%20projets%20pourraient%20%C3%AAtre%20formidables%20-%20mais%20placer%20chaque%20table%20de%20donn%C3%A9es%20et%20chaque%20trac%C3%A9%20dans%20la%20m%C3%AAme%20fen%C3%AAtre%20vole%20%C3%A0%20Jmp%20une%20grande%20partie%20de%20sa%20puissance%20pour%20%C3%AAtre%20utile.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
Add option to not contain all windows to JMP Project's
Participating in JMP Lab during JMP Discovery Summit Europe 2023 where I did use Projects (I don't really use them, but I do see that there could be potential) with multiple data tables and reports at the same time.
One of the biggest reasons why I don't use JMP projects at all, is that it will contain all (non-modal) windows to the project. What I would like to see is to somehow limit which will be added to project (check box selector for different window types for example, JMP17 provides quite a few of different window types for example). Below is an example where Fit Y by X platform is contained in the Project
but I would like it to open as the normal Launcher window like it would open from data table and then add the report to project when I click Run.
Why is this idea important?
Improves the user experience of using JMP Project's by not containing everything inside the project.
2 Comments
hogi
Level XII
I agree so much.
Projects could be great - but putting every data table and plot into the same window steals Jmp large part of its power to be useful.
jc510_2
Level III
Definitely agree with adding more flexibility for non-modal windows!
