Participating in JMP Lab during JMP Discovery Summit Europe 2023 where I did use Projects (I don't really use them, but I do see that there could be potential) with multiple data tables and reports at the same time.
One of the biggest reasons why I don't use JMP projects at all, is that it will contain all (non-modal) windows to the project. What I would like to see is to somehow limit which will be added to project (check box selector for different window types for example, JMP17 provides quite a few of different window types for example). Below is an example where Fit Y by X platform is contained in the Project
but I would like it to open as the normal Launcher window like it would open from data table and then add the report to project when I click Run.
Why is this idea important?
Improves the user experience of using JMP Project's by not containing everything inside the project.
