Add-in template to include Maximum JMP Version allowed
I would like to request a new option for the JMP add-in platform to be placed on the ‘General Info’ tab either below or next to the ‘Minimum JMP Version’:
Maximum JMP Version:
Similar to the ‘Minimum JMP Version’ option, the ‘Maximum JMP Version’ option would have a drop down list of JMP Versions starting with 9 through the current version of JMP.
6 Comments
SamGardner
Level VII
Status changed to: New
@mark_anawis if you use the Add-In Manager (https://community.jmp.com/t5/JMP-Add-Ins/Add-In-Manager/ta-p/43736) , it allows you to specify both a min and max version.
mark_anawis
Level IV
Thanks, Sam. That is true but then we would need to validate the Add-in Manager since it is not part of the JMP application. It would be best for us if it was part of the JMP application.
Sarah-Sylvestre
Level V
@mark_anawis - Thank you for your suggestion! We have captured your request and will take it under consideration.
mia_stephens
SamGardner
Level VII
We plan on providing this option in JMP version 18.
Sarah-Sylvestre
Level V
Status changed to: Delivered
