Add an odds ratio in ordinal logistic regression analysis
In ordinal logistic regression the odds ratio (under proportional hazards assumption) is the usual measure of effect size. This odds ratio is available in nominal logistic regression but not in ordinal logistic regression. It can be rather easily calculated from parameter estimates but I would appreciate that this additional step be available in JMP.
3 Comments
Sarah-Sylvestre
Level V
@winfriedkoch0 - Thank you for your suggestion! We have captured your request and will take it under consideration.
mia_stephens
Thank you for this request. Odds ratios for ordinal logistic regression models will be available in a future release.
Sarah-Sylvestre
Level V
Status changed to: Delivered
