  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Add histograms to the JMP profiler
Sometimes, long tails, distant modes or outliers that are part the initial data can be misleading in the profiler. As the profiler is not showing the data, there might be a lot of iteration plotting and visualizing those. With minor modifications in the profiler, one could visually detect all of these issues, see example below.
4 Comments
winfriedkoch0
Level IV
I support the proposal but I assume that adding the distribution would be available as an option; otherwise more comprehensive profilers would be overloaded.
FN
Level VI
Within the marginal model plots, one can activate the option to see the data.
The main problem is that each plot is individual, so if you want to change dot size or transparency you need to do it one by one.
Sarah-Sylvestre
Level V
Hi @FN, thank you for your suggestion! We have captured your request and will take it under consideration.
hogi
Level XIII
