JMP Tips
Format Values in Prediction Profilers
To change the format of values and their confidence intervals in Prediction Profilers, change the format of the response column in the associated data table.
  1. In a data table, right-click the response column and select Column Info.
  2. Change the format and click OK.
  3. Run the Prediction Profiler report.
In the examples below, the initial format is updated from Best, Width 10 to Fixed Dec, Width 10 Dec 2 (which shows only two places after the decimal point).
Initial Format of Values in ProfilerInitial Format of Values in Profiler
Initial Format: Best, Width 10
Updated Format of Values in Profiler
Updated Format: Fixed Dec, Width 10 Dec 2
