JMP Tips
Filter and Search Columns
When you select an analysis platform from the Analyze or Graph menus, a launch window appears. All of the columns in your data table appear in the Select Columns list. If your data contains many columns, you can use the filters or search for a specific column.
To search for a specific column:
1. Click the red triangle under Select Columns.
2. Click Show Filter (unless it is already selected).
3. Above the list, type a column name.
Column Filter MenuColumn Filter Menu Column Filter OptionsColumn Filter Options
