Learning Library
Fill a Column with Values
There are two ways to repeat a set of values down a data table column.
Using a Fill Command
  1. Highlight the values that you want to repeat and right-click.
  2. Select Fill > Repeat sequence to end of table.
Fill MenuFill Menu
Filled Values
Using Copy and Paste
  1. Highlight the values and select Edit > Copy.
  2. Highlight the destination cells and select Edit > Paste.
The paste operation cycles through the cells in your selection repeatedly until your destination cells are filled.
