Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
JMP will suspend normal business operations for our Rest and Recharge Day on Friday, October 2, 2026.
My technical explanations might not be correct and I might use wrong terms here and there, as I don't fully care to understand everything (only most) what is going on JMP and JSL, I just want my code to work well and fast.
Tip1 Enable JMP Script Editor's Embedded Log
Enabling embedded log allows you to quickly and easily see JMP Log directly in JMP's Script Editor. You can enable Embedded Log from JMP Preferences under Script Editor. JMP16 also allows you to change the height of Embedded log (I personally use values between 25%-30%).
With JMP16 new feature was released called Enhanced Log. This keeps track what you have done interactively in JMP and provides script to those actions and makes it easier to let JMP write scripts for you. Enhanced Log can be enabled from JMP's Preferences. You can also make modifications on what is captured and how the Enhanced Log looks.
Tip3 Evaluating values from variables to expressions
This is fairly common topic in JMP Community: why value from variable isn't getting evaluated into formula for example. This basically means that the values didn't get evaluated "out of" the expressions (variables). Below are for examples to demonstrate the issue and possible solutions (my preferred method is Eval(EvalExpr()) + Expr()).
Example1 Formula
In this example two columns are being created, one without and with Eval(EvalExpr()). The one without is left with the variable name in formula
Names Default To Here(1);
// Create demo table
dt = New Table("Demo",
Add Rows(6),
New Column("Label", Character, "Nominal", Set Values({"A", "A", "A", "B", "B", "B"})),
New Column("x", Numeric, "Continuous", Format("Best", 12), Set Values([1, 2, 3, 4, 5, 6])),
New Column("y1", Numeric, "Continuous",
Set Values(
[0.540628764079884, 0.0138843499589711, 0.363861175486818, 0.697015449637547, 0.114948588656262, 0.685370508348569]
New Column("y2", Numeric, "Continuous",
Set Values(
power = 3;
new_col = dt << New Column("x to " || char(power), Numeric, Continuous, Formula(:x^power));
Show(new_col << Get Formula);
power = 4;
Eval(EvalExpr(new_col = dt << New Column("x to " || char(power), Numeric, Continuous, Formula(:x^Expr(power)))));
Data table and formulas (take note how formulas look like and what has happened to x to 3 values (they are to power 4 now))
If you were to save this data table, reopen it and added new row, you would get following error message, because the data table doesn't know what power's value is.
This is because I'm using Names Default To Here(1); in the example script, but the error is a good thing in this case. If I wasn't using Names Default To Here(1); to start my script (see extra tip), I would add the power variable to global namespace and the data table would still know power value in the same JMP session. Now I might thing that my data table works as it is supposed to and I go sharing the table and who ever I shared it to will be left wondering why it isn't working.
Example2 Set Spec Limits
This example script demonstrates how you can use Eval(EvalExpr()) to get values into column properties (in this case Spec Limits).
If you run this script and close the bivariate window, you will notice that Semiconductor Capability table is being closed instead of Big Class. This is because when the bivariate window is closed, dt is already referencing to Semiconductor Capability (could have also used different variable name, for example dt_semi)
dt = Open("$SAMPLE_DATA/Big Class.jmp");
biv = dt << Bivariate(Y(:Weight), X(:Height), Nonpar Density);
biv << On Close(
close(dt, no save)
dt = Open("$SAMPLE_DATA/Semiconductor Capability.jmp");
And if you run this code, the correct table will get closed. This is because we are evaluating the reference into the Big Class table to the << On close statement
Extra Tip Start your scripts with Names Default To Here(1);
This will protect you from polluting namespace with global variables and avoid issues down the road. This is something I do always when I start a new script file even if I were to to use custom namespace. I do this to avoid even creating by accident variables in global namespace.
@Ressel, personally I'd avoid Clear Globals(1) since it may interfere with other scripts that may be running. It would be much safer to scope any script variables locally or to their own Namespace.
I agree with @DonMcCormack , it's better not to clear the global variables. One example of why you wouldn't want to do that could be when you have a "Recall" functionality in your script, where you can click the Recall button and then any variables or columns that you've cast into roles or values you've entered for use in a JMP platform are automatically replaced and you don't have to go back and do that manually. If you have the clear globals(1) at the start of your script, each time you run the script, your recall variables will be cleared from memory, effectively making the recall function useless.
