DownloadSemiconductor Toolkit: Tools to create wafer maps, add wafer geometry to graphics, explore die defects & compare wafers.
Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
Use JMP Clinical with CDISC-compliant data. Review studies, ID safety and efficacy signals & communicate findings with interactive graphics. Register to see how. Aug. 27, 2 pm US ET.
I have attached the files I used in my part of the session.
In addition I have added code for my dark theme I use for JMP's Python Script Editor. If you wish to use it be sure to understand how those themes work, I haven't had any issues (yet), this is old wish list item so I'm not sure if all the comments are relevant anymore https://community.jmp.com/t5/JMP-Wish-List/JSL-Text-Editor-Color-Themes/idi-p/56203/page/2. The "theme" is controlled by JMPStyles.PFS file found from C:\Users\<username>\AppData\Roaming\JMP\JMP\18 (for windows)
Example of the theme:
Copy paste the theme from here and save it as JMPStyles.PFS (JMP Community doesn't support uploading .PFS files)
The HDBSCAN demo I did does require JMP Pro due to using JMP's Multivariate Embedding platform.
Orange parts are for JMP and blue for Python
I'm mostly getting started with the Python integration in JMP so my Python code definitely isn't the cleanest one, but for a quick example it should be good to go.
I use Python Send() to send variables to Python side
import hdbscan
import jmp
import numpy as np
import pandas as pd
df = pd.DataFrame()
for colname in cluster_cols:
df[colname] = np.array(dt[colname])
clusterer = hdbscan.HDBSCAN(min_cluster_size=int(clustersize), min_samples=int(samples), cluster_selection_epsilon=epsilon)
cluster_labels = clusterer.fit_predict(df)
df['Clusters'] = cluster_labels
col = dt.new_column("CLUSTERS", jmp.DataType.Numeric, jmp.ModelingType.Nominal)
dt[col.name] = list(df.iloc[:,2])
new_col = col.name
del df
The example first runs dimension reduction (tsne or umap), hdbscan on created two columns, displays graph, sets table script to re-create plot, groups columns and sets HDBSCAN parameters to CLUSTERS note column properties
As Python Get Graphics() has been deprecated you have to figure out other ways to get images from Python to JMP. JMP's example show how you can do it by first saving the image and then using JMP's Open() to load the image to JMP. I did demonstrate how you can use python modules io and base64 to load the image to JMP
Finally I want to note that there are many ways to perform the transformation between pandas dataframe and JMP datatable. You can for example do "direct" transform using .csv files, use list(df.iloc[:,2]) or df[col].values.tolist(). There are examples of all of these and I haven't yet made my self familiar with the different methods to be able to make recommendations what you should use.
hdbscan_fulldemo.jsl
scripters_club_python.jsl
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '767254' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '767254') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '767254') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
