Scripters Club Recording: Running Python Code within JSL
maria_astals
Presenters: @martindemel and @jthi
You may also want to watch the recording from West Coast Scripter's Club session on Python integration in JMP 18 from Paul Nelson
Running Python Code within JSL.mp4
Video Player is loading.
Current Time 0:00
Duration 51:26
Loaded: 0.32%
Stream Type LIVE
Remaining Time 51:26
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    Ressel
    Re: Scripters Club Recording: Running Python Code within JSL
    Another dizzying session - so many more amazing things to learn!
    Will the script that @jthi used for the on screen demos be shared?
    yes, Jarmo will add the files here soon
    /****NeverStopLearning****/
    @Ressel just added the files!
    Georg
    great presentation, thanks for preparing the stuff and sharing!
    Georg
    I have attached the files I used in my part of the session.
    In addition I have added code for my dark theme I use for JMP's Python Script Editor. If you wish to use it be sure to understand how those themes work, I haven't had any issues (yet), this is old wish list item so I'm not sure if all the comments are relevant anymore https://community.jmp.com/t5/JMP-Wish-List/JSL-Text-Editor-Color-Themes/idi-p/56203/page/2. The "theme" is controlled  by JMPStyles.PFS file found from C:\Users\<username>\AppData\Roaming\JMP\JMP\18 (for windows)
    Example of the theme:
    Copy paste the theme from here and save it as JMPStyles.PFS (JMP Community doesn't support uploading .PFS files)
    View more...
    //*** Generated Text, Editing this incorrectly may risk not being able to start JMP ***
    Styles(
    	Dark(
    		Python(
    			Default Enabled(
    				Foreground Color({248, 248, 242}),
    				Background Color({12, 16, 33})
    			Default Disabled(),
    			Comment(
    				Foreground Color({117, 113, 94})
    			Comment Blocks(
    			Number(
    				Foreground Color({230, 219, 116})
    			String(
    			Decorators(
    			Quoted string(
    			Triple Quotes(
    			Triple Double Quotes(
    			Keyword(
    				Foreground Color({78, 201, 176})
    			Identifiers(
    				Foreground Color({220, 220, 220})
    			Operators(
    			Line Number(
    				Foreground Color({220, 220, 220}),
    			EOL(
    			Brace Light(
    				Foreground Color({204, 221, 255}),
    				Background Color({14, 69, 131})
    			Bad Brace(
    				Background Color({107, 4, 3}),
    				Foreground Color({221, 221, 221})
    Few comments of my examples
    The HDBSCAN demo I did does require JMP Pro due to using JMP's Multivariate Embedding platform.
    Orange parts are for JMP and blue for Python
    I'm mostly getting started with the Python integration in JMP so my Python code definitely isn't the cleanest one, but for a quick example it should be good to go.
    I use Python Send() to send variables to Python side
    Python Send(dt);Python Send(cluster_cols);Python Send(clustersize);Python Send(samples);Python Send(epsilon);
    and then Python Submit() to run the code below
    import hdbscan
    import jmp
    import numpy as np
    import pandas as pd
    df = pd.DataFrame()
    for colname in cluster_cols:
    	df[colname] = np.array(dt[colname])
    clusterer = hdbscan.HDBSCAN(min_cluster_size=int(clustersize), min_samples=int(samples), cluster_selection_epsilon=epsilon)
    cluster_labels = clusterer.fit_predict(df)
    df['Clusters'] = cluster_labels
    col = dt.new_column("CLUSTERS", jmp.DataType.Numeric, jmp.ModelingType.Nominal)
    dt[col.name] = list(df.iloc[:,2])
    new_col = col.name
    del df
    The example first runs dimension reduction (tsne or umap), hdbscan on created two columns, displays graph, sets table script to re-create plot, groups columns and sets HDBSCAN parameters to CLUSTERS note column properties
    As Python Get Graphics() has been deprecated you have to figure out other ways to get images from Python to JMP. JMP's example show how you can do it by first saving the image and then using JMP's Open() to load the image to JMP. I did demonstrate how you can use python modules io and base64 to load the image to JMP
    Python Submit("\[
    import base64
    import io
    import matplotlib.pyplot as plt
    plt.clf()
    plt.plot([1, 2, 3, 4])
    plt.ylabel('some numbers')
    plt.draw()
    my_iobytes = io.BytesIO()
    plt.savefig(my_iobytes, format='png', bbox_inches='tight')
    my_iobytes.seek(0)
    base64data = base64.b64encode(my_iobytes.read()).decode()
    img = Open(Char To Blob(Python Get(base64data), "base64"), "png");
    nw = New Window("test", img);
    Finally I want to note that there are many ways to perform the transformation between pandas dataframe and JMP datatable. You can for example do "direct" transform using .csv files, use list(df.iloc[:,2]) or df[col].values.tolist(). There are examples of all of these and I haven't yet made my self familiar with the different methods to be able to make recommendations what you should use.
