JMP Scripters Club Discussions
Scripters Club Recording: JMP Scripting: Best Ways to Get Started
(view in My Videos)
hogi
Level XIII
Re: Scripters Club Recording: JMP Scripting: Best Ways to Get Started
"Application Builder keeps everything in it's own namespace"
Are there any tricks for Debugging Jmp applications - or tfor debugging scripts which are included in other scripts.
How to get access to this well contained namespace?
hogi
Level XIII
Thanks for discussing the issue with JMP preferences:
auto-generated JSL code can generate wrong reports if you dare to change the preferences.
Here is a post about this issue:
Do you use the preferences?
and here is a wish to fix the issue:
Changed Settings in the Preferences - fix the issue
