- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
- Report Inappropriate Content
JSL Tips and Tricks session on November 20th
Dear community,
On November 20th, we'll be hosting a Scripters Club session on "Tips and Tricks." You can find more details and register here: https://www.jmp.com/en_gb/events/users-groups/users-group-meetings/register-for-scripters-club-2024....
We have a list of items we'd like to cover, but we'd also love to hear from you!
- Is there anything you'd like to learn more about?
- Are there specific challenges you face when scripting?
- Do you have a tip you'd like to share with the community?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: JSL Tips and Tricks session on November 20th
Maybe I can give some possible ideas regarding the tips:
- Re-ordering
- Re-ordering associative array
- Re-ordering columns based on some metric
- Scripting Index tips and tricks
- Finding references to display boxes
- Extracting values between brackets
- Getting unique values
- Data table subscripting
- Opening text as data table
- Quotes in Run Command
- Square brackets in regex
- Escaping escapes
- Randomizing things
- Finding platform preferences from already open (report) windows
- Getting possible combinations
- "Testing" expression evaluation
- SQL queries in JSL
- Log Capture()
- Referencing columns
- Column()
- Eval("name")
- Enable "filter" for filter col selector
- Making private tables visible
- Batch Interactive
- Checking for missing/empty/no items/...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
- how to debug code in Application Builder
- How to debug code in a jsl file which is "included" in another file?
i.e. how to access the namespace.
efficient ways to work with JSL debugger :
do I have to start it every time "from scratch"? can I change values of symbols "on the fly" ? can I jump back to the start of function?
how to extract information from saved scripts. e.g. Variable or axis setting of Graph Builder Script
JSL and Workflow Builder?
how to handle the part of the workflow which is not recorded by Workflow Builder?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
collection of some Tips and Tricks - best practice with JMP/JSLwhich I found in the community.
I just added the most important one to the list:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
wonderful tips and tricks with XPath:
https://community.jmp.com/t5/Abstracts/I-Can-See-It-How-Do-I-Get-It/ev-p/776041
question: how to make XPath robust so that it works as well with local language settings?
Display Tree Indexing - how does it work?
names default to here(1);
dt=Open("$SAMPLE_DATA/Quality Control/Coating.jmp");
obj=dt<<Control Chart Builder( Variables( Subgroup( :Sample ), Y( :Weight, :Weight 2 ) ), Local data filter );
rpt=obj<<report;
rpt["Control Chart Builder","Weight Limit Summaries"]; // works , even with local language settings - wow!!!
rpt["Qualitätsregelkarte erstellen","Übersicht Grenzen Weight"] // works - but just with German language setting
current report()["Local Data Filter"]; // works, but NOT with local, e.g. German language setting
current report()["Localer DatenFilter"]; // works - but just with German language setting
rpt << xpath("//OutlineBox[text()='Control Chart Builder']"); // works - but just with English language settings
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
temporary variables in column formulas - used again in subsequent rows:
If(Starts With(:Column 1, "Header"),
flag = :Column 1
flag;
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
(non-modal) dialog windows in sequential scripts
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Log how a list is sorted:
Sort( {{111,1}, {212,2},{4,3}} )
- sorted by first entry
- send entry for the log
