Learn how to build custom Python data connectors and further customize JMP’s Data Connector Framework with the Python Data Connector Demo, available now in the JMP Marketplace!
See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
flood = Function({},
Try(:"neighbors_dir+diag"n<< get name(), Caption("can you tell me the direct and diagonal neighbors ?!?"); stop());
dt = current data table();
nr = n rows(dt = dt);
Try(:wall; dt << delete column(:wall));
new column("wall", Nominal, set each value(1));
:wall[1]=2;
dt << Graph Builder(
Show Control Panel( 0 ),
Variables( X( :X ), Y( :Y ), Color( :wall ) ),
Elements( Points( X, Y, Legend( 4 ) ) )
wait(1);
dt << begin data update();
// mark additional pixels as wall "2" if the neighboring pixel belongs to wall 2 - swipe from top to bottom, then inverse - and so on ...
for( i = 1, i<16, i++ ,
for each ({rw}, 1::nr,
if(rw>1,
:wall[rw] = max(:wall[:"neighbors_dir+diag"n[rw]])));
for each ({rw}, reverse(1::nr),
if(rw>1,
dt << end data update();
wait(0.1);
