  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Process Capability - Non-normal Indices
Hello,
I would like to recommend the following enhancements to the Process Capability platform, specifically as pertains to non-normal indices (i.e., where no distribution fits and indices are calculated based on percentiles).
1. Allow calculation based on actual percentiles, separate from using a curve fit (currently, the calculation for non-parametric distributions uses Smooth Curve).
2. Allow calculation of metrics based on different percentile ranges, with suitable scaling factors based on normalizing the distribution and sample sizes, conceptually similar to what is done for robust-sigma calculations. Examples listed below.
0.00135 – 0.99865 => 1
0.005 – 0.995 => 0.859
0.05 – 0.95 => 0.548
0.1 – 0.9 => 0.427
0.25 – 0.95 => 0.225
Thanks and regards
Mehul Shroff
