Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
In this thread I will collect and add some exercises I use in JMP Days or Workshops to have an easy to grab location for people joining those sessions.
This is a living thread I update from time to time with new/adjusted material or new information. There are many good resources to learn JMP (like STIPS, Welcome Kit, Mastering JMP, Trainings, ...) and this thread is no replacement for these. It really is to have one location I can point to in my sessions where I have some homework/hands-on activities.
We use the "Tablet Production.jmp" Sample Data Set in JMP (Help -> Sample Data ->See alphabetic List of all Sample Data Files
Session Exercise:
How much data is outside the specification limit of the response "Dissolution"? Use e.g. Control Chart Builder
Using Graph Builder, what are the potential drivers on Dissolution? Are there some potential nonlinear effects, in what variables?
Homework Exercise:
Proof that Screen Size has significant impact on Dissolution! Use e.g. Analyze -> Fit Y by X. Then recreate Control Chart for "Dissolution" and filter by Screen Size. Note the differences in the out of spec results for Dissolution.
What would be a setting to avoid running out of spec? Use e.g. Analyze->Predictive Modeling->Partition platform to understand the combined effects driving less out of spec settings
Essentials for Designing an Experiment
This is the use case:
Session Exercise:
Create a screening design with the custom designer leaving the default settings
Analyze the results using the "Model" Script as well as Graph Builder to understand what factors seem to have an impact on yield. (using "Chapter 2 results.jmp" attached in this post)
Homework Exercise:
Create the same screening design in the custom designer as in the exercise, but with minimum runs as well as with more runs. What can you say about the Power of the design? What design would you choose when you have to decide?
Read through What is correlation? and What is regression? in the statistical knowledge portal to understand what the p-value represent and what a linear model is.
In preparation of the next session about Screening and Definitve Screening Designs read through this blog post by Bradley Jones, one of the inventors (next to Chris Nachtheim) of Definitive Screening Designs.
Essentials about Screening and Definitive Screening Designs
We discuss this use case:
These are the factors considered:
Session Exercise:
Create a Definitive Screening Design using the attached factors table ("DSD Factors.jmp") and the default settings
Analyze the results in the attached JMP data table "DSD Results.jmp" using the "Fit Definitive Screening" Script
Create different traditional Screening Designs with about the same number of runs and compare these to the DSD approach
Homework Exercise:
Review proper use of Definitve Screening Designs by reading through this blog post by Bradley Jones, one of the inventors (next to Chris Nachtheim) of Definitive Screening Designs.
RSM, Robustness, and QbD
Files: Factors.jmp - Robustness DOE Example.jmp - Optimal Robust Example.jmp
