キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
German, Swiss, Austrian JMP Users Group
言語を選択 翻訳バーを非表示
Level XIII
Nützliche Hilfsmittel zur explorativen Datenanalyse
Dr. Holger Specht, Principal Engineer R&D - ams OSRAM Group
Wish List: https://community.jmp.com/t5/JMP-Wish-List/idb-p/jmp-wish-list
#DACH2024
6件の返信6
Level XIII
Re: Nützliche Hilfsmittel zur explorativen Datenanalyse
AddIns which were presented in the talk:
*) flood script:
詳細を表示...
flood = Function({},
Try(:"neighbors_dir+diag"n<< get name(), Caption("can you tell me the direct and diagonal neighbors ?!?"); stop());
dt = current data table();
nr = n rows(dt = dt);
Try(:wall; dt << delete column(:wall));
new column("wall", Nominal, set each value(1));
:wall[1]=2;
dt << Graph Builder(
	Variables( X( :X ), Y( :Y ), Color( :wall ) ),
	Elements( Points( X, Y, Legend( 4 ) ) )
wait(1);
dt << begin data update();
// mark additional pixels as wall "2" if the neighboring pixel belongs to wall 2 - swipe from top to bottom, then inverse - and so on ... for( i = 1, i<16, i++ , dt << begin data update(); for each ({rw}, 1::nr, if(rw>1, :wall[rw] = max(:wall[:"neighbors_dir+diag"n[rw]]))); for each ({rw}, reverse(1::nr), if(rw>1, :wall[rw] = max(:wall[:"neighbors_dir+diag"n[rw]]))); dt << end data update(); wait(0.1); ); )
Level XIII
Graph builder remote control
once it's running smoothly, I will update Graph Builder Toolbar .
For beta testing, please use the attached version.
v5.1:
- bugfix for numeric columns
- help: explain the gui
Level XIII
Level XIII
Normalize is now available via the Marketplace:
https://marketplace.jmp.com/appdetails/Normalization+GUI
Level XIII
Hi @Byron_JMP .
a current beta version of GraphBuilder Remote control can be found here.
Level XIII
GraphBuilder_Toolbar: new beta v7
