xiaoyaj0
unique variance for each variable in multiple regression
In the attached dataset and screenshot, I am trying to find the effect of prior academic achievement and SES on current achievement for students. How could I find the unique variance/semipartial correlation for each variance? I know it is not the square of standard beta for the variable. Any ideas? Thank you!
jiancao
Re: unique variance for each variable in multiple regression
JMP doesn't report semipartial correlations directly, but they can be calculated from regressions.
For example,  to get the semipartial correlation for socioeconomic status, first, run two regressions as shown in the screenshots.
Then take the sqrt of the difference in RSquare values between the two models, i..e. sqrt(0.723934-0.715378)=0.0925. This indicates the "unique" contribution of socioeconomic status as a predictor.
jiancao
