Woodstock
unable to save file from dt object in jsl
Re: unable to save file from dt object in jsl
Could you please provide more details on this issue. Both the script and the error message would help in being able to determine the issue.
Woodstock
Hi Jim,
When I realized it was a pebkac error, I tried to delete the thread, but there wasn't a painfully obvious way to do so.
