BookmarkSubscribeRSS Feed
kuannygoh
Occasional Contributor
Oct 21, 2018
unable to eval a formula in a table
Hi all ,
 I am trying to eval a expression in a formula but it seems to have error, can someone help me ?
My formula is below:
		dtmaster << New Column("_SBL",
			Numeric,
			Formula(
				 (Match( :Selected_Sigma,
					"Flag_3Sigma",Eval expr(((column(8)- column(6)) / 3) * 3 + column(6)),
					"Flag_4Sigma",Eval expr( ((column(8)- column(6)) / 3) * 4 + column(6)),
					"Flag_5Sigma",Eval expr(((column(8)- column(6)) / 3) * 5 + column(6)),
					"Flag_6Sigma",Eval expr(((column(8)- column(6)) / 3) * 6 + column(6))
			Format( "Percent", 12, 2 )
uday_guntupalli
Community Trekker
Sep 15, 2014
Re: unable to eval a formula in a table
@kuannygoh ,
      May I ask why you are trying to using eval function ? What are you actually trying to achieve ?
      If you absolutely want to use the Eval Expr, kindly take a look at the scripting index ecample shown below:
Best
Uday
Mar 21, 2013
yes, try removing the EvalExpr. It isn't needed and is causing at least part of the problem you are seeing.
kuannygoh
Oct 21, 2018
Hi I tried removed, but it still shows error. I am trying to match the column of selected sigma with formula.
kuannygoh
Oct 21, 2018
kuannygoh
Oct 21, 2018
Hi, the error shown is as attached in image
Mar 21, 2013
dt = Open( "$sample_data/big class.jmp" );
dt << New Column( "H_OR_W",
	Numeric,
	Formula(
		(Match( :sex,
			"F", height, // height
			"M",
				Column( 5 )[] // weight
if you use an explicit column name, like height, above, then JMP knows to index with the current row. If you use the column function to specify the column, you still need to index into the column. You can use the empty subscript shown above to tell JMP to use the current row. See the weight example above.
