Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
When I perform the equivalence test, all 3 p-values are greater than 0.09. Therefore, I do not have enough evidence to prove X is better than Y, Y is better than X, or that they are equivalent.
