hogi
Level XIII
JSL: change drawing order
Is there a JSL command to change the order of segs?
Re: JSL: change drawing order
There is Reorder Segs which might work
dt = Open("$SAMPLE_DATA\Big Class.jmp");
gb = Graph Builder(
	Size(534, 456),
	Show Control Panel(0),
	Variables(X(:height), Y(:weight)),
	Elements(Points(X, Y, Legend(6)), Bar(X, Y, Legend(7))),
		Dispatch({}, "weight", ScaleBox,
			{Label Row({Show Major Grid(1), Show Minor Grid(1)})}
For(blink = 1, blink < 4, blink++,
	Wait(.5);
	(gb << report)[FrameBox(1)] << reorder segs({4, 3, 2, 1});
Depending on elements you wish to move there might also be other options
gb = Graph Builder(
	Size(534, 456),
	Wait(.5);
hogi
Level XIII
Thanks @jthi  : )
