razmah
set a formula for columns with variable name
I have 3 columns with variable names.
how can I add new column and give it a formula by use of a,b, and c?
I wrote following script but column doesn't show the formula.
New Column( "a /b",Numeric,Continuous,Format( "Best", 12 ),
Formula( :column(char(a)) /  :column( char(b)) ));
thank you for your recommendation
pmroz
Re: set a formula for columns with variable name
Ah OK.  Here's a better example:
a = 10;
b = 20;
dt = New Table( "Example", Add Rows( 3 ),
     New Column( char(a), Numeric, Continuous, Format( "Best", 12 ),
           Set Values( [1, 2, 3] ) ),
     New Column( char(b), Numeric, Continuous, Format( "Best", 12 ),
           Set Values( [4, 5, 6] ) ),
new_expr = evalinsert(
"\[dt << New Column( "a/b", Numeric, Continuous, Format( "Best", 12 ),
     Formula( :Name( "^a^" ) / :Name( "^b^" )))]\");
eval(parse(new_expr));
pmroz
This will work:
a = "weight";
b = "height";
dt = open("$sample_data\Big Class.jmp");
"\[dt << New Column( "a/b",Numeric,Continuous,Format( "Best", 12 ),
Formula( :^a^ / :^b^ ))]\");
razmah
My "a" and "b" are not name; thay are numbers.
do I need any changes for that? because I tried your script, it didn't work for me.
pmroz
a = 10;
b = 20;
razmah
GREAT! Thanks
pmroz
For those not familiar with evalinsert or \[...]\:
evalinsert allows the insertion of variables surrounded by the caret character "^".  Makes it easier to build a string containing variables by avoiding lots of concatenating.
The special characters \[ in a string tell JMP not to interpret anything in the string, until you see the characters ]\.  Allows for clean insertion of double quotes, among other things.
gutloja
Hello, Razmah.
If all you want is to insert a new column to an already open file, with a formula using "A", "B, and "C" columns [from your data table], just run a similar script on your Script Editor:
    New Column( "A/B", Numeric, Continuous, Format( "Best", 5 ), Formula( a / b ) );
    New Column( "B/C", Numeric, Continuous, Format( "Best", 5 ), Formula( b / c ) );
    New Column( "C*D", Numeric, Continuous, Format( "Best", 5 ), Formula( c * d ) );
    New Column( "A+C+B", Numeric, Continuous,Format( "Best", 5 ),Formula( a + b + c));
Your script is missing the "Formula ( ) " function.
-Jose
