razmah
How to select a column with specific name?
Hi
Assume I have a table with columns 1-10.
then I have a 3 variables. for example A=2, B=7, C=10
I want to write a script to select columns with amounts of A, B, and C and plot it vs col.1.
here it should select columns of 2, 7, and 10 and use overlay plot to plot it vs column1.
Thanks
Eric_Hill
Re: How to select a column with specific name?
Selecting columns by name is easy enough:
dt = Current Data Table();
a = 2;
b = 7;
c = 9;
Column( dt, Char( a ) ) << Set Selected;
Column( dt, Char( b ) ) << Set Selected;
Column( dt, Char( c ) ) << Set Selected;
But I'm not sure you need to select them to create the overlay plot you are looking for.  You can just do this:
Overlay Plot( X( :Name( "1" ) ), Y( Column( dt, Char(a) ), Column( dt, Char(b) ),
   Column( dt, Char(c) ) ) );
If you have a variable number of Y variables, you can construct a list of them and set that list as the Y variables for overlay plot:
colList = {};
colList = Insert( colList, Column( dt, Char( a ) ) );
colList = Insert( colList, Column( dt, Char( b ) ) );
colList = Insert( colList, Column( dt, Char( c ) ) );
Overlay Plot( X( :Name( "1" ) ), Y( EvalList(colList) ) );
HTH,
Eric
Eric_Hill
a = 2;
b = 7;
c = 9;
colList = {};
HTH,
Eric
pmroz
If you want to use column 1 as x, and columns 2, 7, and 10 as Y, regardless of their names, then this will do the trick:
dt = current data table();
xc = 1;    // column 1
a = 2;     // column 2
b = 7;     // column 7
c = 9;     // column 9
overlay plot(x(column(xc)), y(column(a), column(b), column(c)));
razmah
Hi Eric,
I have another question looks like last one:
columns a, b, c are variables; how can I add new column and give it a formula by use of a,b, and c?
I wrote following script but column doesn't show the formula.
New Column( "a /b",Numeric,Continuous,Format( "Best", 12 ),
Formula( :column(char(a)) /  :column( char(b)) ));
thank you for your recommendation
