BookmarkSubscribeRSS Feed
chang
Jul 11, 2012
script to export a plot and summary of survival analysis to a MS word
I've had script for a survival analysis that could produce (1) a failure plot, (2) summary and test between groups for two comparison group. I've tried to export these to a journal and save as a MSword, nothing happened. Even the file "JournalTest.doc" did not appear in the folder. Could you please help me revise my codes? I've attached my data table and a test journal that shows what I want. Shorten my codes wherever possible.
// get all the rows from database
dbq_string = "DBQ=E:\Now\(Project) RFID_r3_Homing_r1\Ben analysis\Chang_bee_db.mdb;" ||
             "DefaultDir=E:\Now\(Project) RFID_r3_Homing_r1\Ben analysis;" ||
             "Driver={Microsoft Access Driver (*.mdb)};DriverId=25;FIL=MS Access;" ||
             "FILEDSN=C:\Program Files\Common Files\ODBC\Data Sources\chang_bee_db.dsn;" ||
             "MaxBufferSize=2048;MaxScanRows=8;PageTimeout=5;SafeTransactions=0;Threads=3;UID=admin;UserCommitSync=Yes;";
dt1=Open Database(dbq_string, "SELECT * FROM qryAFF14", "qryAFF14", invisible);
// get curves of 3 groups in one failure plots
dt=data table ("qryAFF14", invisible); /*invisible: to closes the data table window*/
dt<< Survival(
    Y( :AFF14 ),
    Grouping( :treatment ),
    Failure Plot( 1 ),
    Survival Plot( 0 ),
    Where( :treatment == "acetone 5µl" | : treatment== "nil" | :treatment == "methoprene 5µll (40 µg/µl)" ),
        Dispatch(
            {"Failure Plot"},
            "Failing",
            TextEditBox,
            {Set Text( "Rates of initiating the first flight" )}
        Dispatch(
            {"Failure Plot"},
            "AFF14",
            TextEditBox,
            {Set Text( "Age (day)" )}
// output the failure plot to a journal. how to modify underlined part for export the plot?
dt<<journal (freeze all);
dt<<close window;
current journal()<<minimize window;
Page Break Box() << Journal;
dts = dt << Summary( Group( :treatment ), N, Mean (:AFF14), Std Error, output table name( "qryAFF14_out" ) );
dts << Journal( Freeze All );
dts << close window;
Current Journal() << save HTML("E:\Now\(Project) RFID_r3_Homing_r1\Ben analysis\JMP\JournalTest.htm");
Current Journal() << save MSWord("E:\Now\(Project) RFID_r3_Homing_r1\Ben analysis\JMP\JournalTest.doc");
Current Journal() << save RTF("E:\Now\(Project) RFID_r3_Homing_r1\Ben analysis\JMP\JournalTest.rtf");
// get summary and tests between group, this part works
dt<< Survival(
    Y( :AFF14 ),
    Failure Plot( 0 ),
    survival plot(0),
    ,Where( :treatment == "acetone 5µl" | :treatment == "nil" ),
<<Survival(
    Y( :AFF14 ),
    Failure Plot( 0 ),
    survival plot(0),
    ,Where( :treatment == "acetone 5µl" | :treatment == "methoprene 5µll (40 µg/µl)" ),
// export summary and tests between group, not working. how to modify script for these two
dt<<journal(freeze all);
dt<<close window;
