New to JMP? Join us Sept. 23-24 for the Early User Edition of Discovery Summit, tailor-made for new users. Register now for free!
Use World Cup data to build models, explore spatial relationships, and create informative visualizations in JMP. Register. July 17, 2 pm US Eastern Time.
Your voice matters! Tell us how you prefer to receive JMP updates, so we can tailor our communication to your needs. Take short survey.
Hello! It seems that there have no built-in options to directly calculate the sample size and power for linear mixed models in JMP. Then, how could I do such kind of power analysis? Thank you.
If you are using JMP Pro 17, you can use an option "Save Simulation Formula" under "Save Columns" in Mixed Model personality. This column can be used in the Simulate utility as a column to switch to.
