FR60
remove almost empty categorical columns
Some one can help me?
From a database i need to remove categorical columns with a certain percentage of missing character and at the same time I would like to remove the numeric columns with a percentage of stagnant values (not necessary 100%).
Thanks.  Felice
msharp
Re: remove almost empty categorical columns
Yeah it all depends on how you set it up. The first check is finding the most common value in each column and determines if it is above or below the threshold percentage. Unfortunately, a missing value isn't a value, so it can't be the most common. That's why it doesn't work on the numeric columns. It does work on the Character columns b/c "" is both missing and an empty string value.
Hope that helps explain things.
If you want more granularity, just run multiple loops with different percentages using different strategies.
9 REPLIES 9
Here is a quick and dirty script that gets rid of columns with less than a specified percent of data
percent = 90;
colList = dt << get column names( character, string );
NumRows = N Rows( dt );
For( i = N Items( colList ), i >= 1, i--,
	If( Col Number( Column( dt, i ) ) / NumRows * 100 < percent,
		dt << delete columns( colList[i] )
msharp
Another method, I believe slightly more robust.
percent = 90;
delcols = {};
numRows = nrows(dt);
for(i=1; maxi=NCols(dt), i<=maxi, i++,
	col = column(dt, i);
	nmissing = col N missing(col);
	if(nmissing > numRows * percent/100,
		insert into(delcols, i);
if(nitems(delcols) > 0, dt << delete columns(delcols));
msharp
I think you are also looking for something like this:
Which will delete a numeric column if all data is only one value.
delcols = {};
	try(summarize(dt, max = max(col), min = min(col));
		if((max == min)  | (ismissing(max)),
			insertinto(delcols, i);
mpl34
you might be able to use the method you posted before but with the mode of the column for something less than 100%
percent = 90;
delcols = {};
	if(nrows(loc(aslist(column(dt,i)<<getasmatrix),mode(column(dt,i)<<getasmatrix))) > numRows * percent/100,
FR60
Hi
I tried yor script on the second table below and the result is here.
As you can see it was able to remove almost all desired columns but second one (col2) not. How I can do to remove it too?
Thanks  Felice
msharp
Just combine the strategies.  Something like:
percent = 90;
delcols = {};
		if(Col N Missing(column(dt,i)) > numRows * percent/100,
FR60
Hi msharp thanks for your reply. Let'm ask another question. The percent variable work for both on categorical and numerical columns? If yes can I have two different value for missing and stagnant cases?
Sorry for maybe stupid question but I'm not expert in jsl language.
Felice
msharp
FR60
Perfect thanks.
Felice
