jswislar
How do I create 3-way interactions in linear regression?
I'm trying to create a model with a 3-way interaction term. I selected the variables and clicked on "cross" per JMP instructions for 2 or more variables. But JMP gives me the following warning:
"The model is missing an effect
X1*X2*X2*X1"
Which is especially odd since what I entered into the model, and what appears in the dialog box, is:
X1
X2
X3
X4
X5
X1*X2*X3
Any thoughts on how to resolve this?
Thanks
Re: How do I create 3-way interactions in linear regression?
If you want the term X1*X2*X3, then you must also include X1*X2, X1*X3, and X2*X3 to maintain the linear model hierarchy, even if these lower order terms are not significant.
jswislar
Ahhh, you're right! I was thinking that only the lower order terms needs to be included. Thanks!
