Created:
Oct 5, 2015 03:51 PM
| Last Modified: Oct 18, 2016 5:50 PM(10286 views)
I am using jmp 12.01 and experiencing the problem "access violation" just after open a JMP session. The exit button in file menu is grayout and can not be closed by any means except use task manager of Windows. below are the screen shots. I have emailed to jmp support but would like to check if any member in this forum can help me out.
The issue was fixed finally by choose File/Preference/Windows Specific/ then click on reset association. I guess some file extension was associated with jmp accidentally and caused the issue.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '14606' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '14606') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '14606') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
